Old 13-Aug-2012, 7:49 AM   #3
jelwell
Originally Posted by thom View Post
Your LOS VHF stations are fine, so I wonder if you're too close to the shadow of your 1Edge. As a test, you could spin around to 328 and see if you fare any better. The other thought is to pull the surge protector and see if that helps. This of course assumes your antenna isn't pointing directly into a tree.
I'll try rotating to 328, I guess that will be a good test on whether I can get LA stations. I live on the west face of Black Mountain. But there is a ridge to the south of me - that's likely my 1Edge.
I'll try pulling the surge protector out - unfortunately I haven't done any grounding on my setup yet. I need to run copper wire to my electrical box, but it's quite a route to get there. When I do get it properly grounded, I imagine the signal will drop again - if that's the problem.
As an aside, if PBS is your goal, there are excellent PBS stations in LA. KOCE and KLCS should be doable, KCET is a sometimes, and KVCR is a roll of the dice. They all have subchannels, and play different programming at any given time.
LA PBS stations would be fine too. All I need is "PBS kids" for my little ones - the children's shows that air in the morning.
Joseph Elwell.
jelwell is offline   Reply With Quote
