Old 25-Sep-2010, 5:49 PM   #23
Billiam
Originally Posted by goosemasterkl View Post
Billiam; what could I do to be able to keep my ABC channel on HI-VHF? Thanks
Tough question.
Can you add any more height to your antenna setup? Try rerunning TV Fool at your location with 25 and 30 foot heights to see if you'd see that Noise Margin (NM) which is currently at minus 0.9 can go into positive territory.
If it does, then adding a VHF antenna might do the trick. Perhaps stacking two Winegard YA 1713's would work. Not sure if one will work on such a weak signal even with a pre amp.
