Tv Reception.
Very good.
I recommend go for the North West group of Tv stations/channels first.
Reason:
The north west group will provide all the Networks except RTV Retro Tv Network.
Install the HD9095P with the CPA-19 preamp and also install a Antennas Direct C5 , VHF antenna to receive WSIU-DT channel 8 PBS at 51 degree magnetic compass direction.
The C5 comes with a combiner to combine the HD9095P and C5 onto 1 coax.
The CPA-19 preamp is connected to the output of the Combiner and the 1 coax goes to your Tv location.
For the best reception the antennas will need to be Up High and the least amount of trees and tree leaves and other obstructions in the directions of reception the better.
___________________________________________
Then at a later date you can install the second system for the south east group of Tv stations/channels.
