Maybe my description is a bit confusing --- I'll try again. The end of the building, where there are no balconies, points to 30 degrees true. So the opposite end points to 210 degrees (180 + 30) if I'm not mistaken. The other two sides of the building have balconies. So in this building, your unobstructed view is either the eastern or western portion if the analysis map, skewed by 30 degrees. Another way to express this is to say one unobstructed view includes a range from 210 degrees to 30 and the other view includes the range from 30 to 210. (30 and 210 can't be really included in both ranges so technically like 210 to 29 and 30 to 209)
So the range of view on my balcony includes 210 and above, and up to 30 true. (I have no windows that have a different field of view than my balcony - my guess is that mounting the antenna on the balcony is my best bet.) The stations I'm asking about are out of my direct field of view. Can the signal make it through my building? And some stations are just out of my view -- do you think I will still be able to pick them up?
