Tv Reception.
Can also run the coax over the edge of the roof the feed the coax behind the straps that hold the rain gutter down tube.
Most attic have electric power outlet so if the coax goes up under the lip of a roof vent and into the attic , then a CM3410 distribution amplifier can be connected in the attic and the coax would continue on through the attic and through the attic wall to the outside of the house , down the outside wall to the box that is on the outside of the house where the coaxes are and connect a splitter there if more then one Tv is connected.
I do not think a amplifier will be required for one Tv connected.
______
The pictures show that the trees are distant from the house , thats good.
Because trees and tree leaves do a real fine job of reducing or blocking Tv transmissions.
The Local Digital Tv transmitters are , north , east , south west . north west.
If there are any trees that are close to the house in the directions of , north east , south west , north west , avoid placing the antenna so the tree will be in the way of reception.
