Thread: Outdoor Antenna
Old 12-Aug-2012, 1:10 AM   #6
Tv Reception.
A simple reception situation.
For reception of All the local Tv stations/channels of All directions install a ANT751 antenna above the roof aimed at about 99 degree magnetic compass direction.
Here is the Federal Antenna Law that says Yes you can , install , use , maintain , Tv antennas of any size and locate the antenna to get reliable reception. http://www.fcc.gov/mb/facts/otard.html.
For 1 Tv connected use no splitter and no amplifier.
For 2 Tv's connected use a Channel Master CM3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
The antenna needs to be Up High for reception of All directions.
The ANT751 is a simple small antenna that has some forward gain , and is not very directional and receives Ok in all directions.
A simple 'J mount' antenna mount can be used with the ANT751.
And here are some other mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
Here are the Local Digital Tv stations/channels.
WTZT-CD Real channel 11 , virtual number (x) , RTV.
WMJN-LP Real channel 29 , virtual channel (29.1) , Religion.
WYAM-LD Real channel 15 , Virtual number (x) , Religion.
WAAY-DT Real channel 32 , virtual number (31.1) , ABC.
WZDX Real channel 41 , virtual number (54.1) , FOX and MyNetwork and Me-Tv.
WHDF-DT Real channel 14 , virtual number (15.1) , The CW.
WHIQ-DT Real channel 24 , virtual number (25.1) , PBS.
WHNT-DT Real channel 19 , virtual number (19.1) CBS and Antenna Tv.
WAFF-DT Real channel 49 , virtual number (48.1) NBC and Bounce Tv.
WHVD-LP Real channel 34 , virtual number (67.1) Religion.
W38BQ Real channel 17 , virtual number (38.1) , Religion.
