Thanks for the reponses. The current address location doesn't come up on TV Fool because this area is very remote. The current address is ****** Colebrook, NH 03576.
This Lava antenna is mounted approximately 25 feet above ground level, but the actual land location is also very elevated. I realize this is probably not the best antenna for the job, but it shouldn't prevent me from getting a TV station (W34DQ) only 6 miles away....right?
We have a Radio Shack indoor antenna 15-1878 which doesn't pick up W34DQ either. How would I verify the TV station is actually broadcasting, because all indications are that it currently is offline?
We are scanning for Antenna only channels on the TV and I was able to get those two Canadian channels without any issue, so I don't believe I am doing something wrong on the TV.
Reason: Protecting OP's privacy
