Old 11-Aug-2012, 11:04 PM   #2
Tv Reception.
The provided tvfool radar plot report is to street level only.
This recommendation is based on the street level report.
Also please provide a tvfool radar report that is the Actual address.
Above the roof install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 322 degree magnetic compass direction.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
As for the Lava scam antenna , return it or put it in the trash.
_____________
W34DQ-D UHF Digital channel 34 , is a ---->Digital<---- Tv transmitter.
W26CQ UHF Analog channel 26 , is a ---->Analog<---- Tv transmitter.
Because of the Digital transition the Analog transmitter is most likely off the air.
Both are the same PBS , http://en.wikipedia.org/wiki/New_Ham...lic_Television.
I see No requirement for a antenna rotator , the Canada Tv stations are in one direction --> so No requirement for a antenna rotator.
And the PBS station/s are so Strong signal strength , that should be received no matter what direction the antenna is aimed.
