Old 11-Aug-2012, 5:23 AM   #2
Tv Reception.
Above the roof install the ANT751 antenna (no antenna amplifier required) aimed at about 315 degree magnetic compass direction.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
________________________________________________________________________________ ________
For 3 Tv's connected use a simple common 3 way splitter.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
The Tv/s Must Channel Scan for the digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna channels" in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
