Tv Reception.
The antennas are being mounted to the same mast and are being aimed in different directions.
All antennas come with their own clamp to clamp the antenna to the mast pipe.
The distances between the 2 antennas mounted on the same mast pipe is a adjustment you make when installing the 2 antennas.
The separation distance between the 2 antennas is not critical.
