Old 9-Aug-2012, 9:51 PM   #6
Tv Reception.
The HDTVa must remain pulged in , and the switch is put in the off position to make it function as a HDTVi.
So get a long coax to reach from the Tv to the window if the 2 are not close.
Omnidirectional antennas in a apartment will make reception worse due to the fact that the Tv signals bounce around in a apartment and a omnidirectional antenna receives all those bouncing around signals and that is not good. So do not use a omnidirectional antenna.
