Tv Reception.
Do Not get the word splitter , tangled up with the antennas that are mounted on the mast.
The 2 antennas can be mounted on the same mast , separate by about 3 feet on the same mast.
It is also a good idea to look at pictures of all the equipment , antennas , amplifiers , splitters and etc. .
Trying to see it all in your mind with out pictures is difficult at best.
The installation goes like this ,
Antenna , preamplifier unit close to the antenna , coax cable to inside the house , power supply/power injector connected to the coax cable so to send power out to the preamp and from the preamp the signal travels on that same coax to the one Tv connected with no splitter.
Or through the power passing 2 way splitter if 2 tv's are connected.
This is one antenna system.
______________________________
The second antenna system is the same kind of setup. , sequence of events , sequence of connections.
________________________________________
The 2 antenna systems are In Fact 2 Separate antenna systems that are separate all the way to the tv or Tv's.
The A/B switch/s is/are used to select one antenna or the other.
