Old 9-Aug-2012, 4:29 PM   #3
Tv Reception.
NO Antenna Rotator Required.
_______
For reception of the Canada Digital Tv stations/channels.
Aim a Winegard HD7084P antenna with a Winegard AP8700 preamp aimed at about 50 degree magnetic compass direction.
For 2 Tv,s connected use a , HFS-2D , 2 way splitter.
http://www.hollandelectronics.com , also at , http://www.solidsignal.com.
_______
->IF <- the Analog Canada Tv transmitters are still transmitting at your location they are duplicates of what is being transmitted by the Digital transmitters.
________________________________________________________________________________ _________________
_______
For reception of the USA Digital Tv stations/channels of.
WWNY-TV Real channel 7 , virtual number (7.1) CBS as the main digital channel and WNYF-CD FOX Network as a digital sub channel.
WPBS-DT Real channel 41 , virtual number (16.1) PBS.
WWTI-DT Real channel 21 , virtual number (50.1) ABC as the main digital channel and The CW as a digital sub channel.
Aim a Winegard HD7698P antenna with a Winegard AP8700 preamp at about 160 degree magnetic compass direction.
For one Tv connected use no splitter.
For 2 Tv's connected use the HFS-2D , 2 way splitter.
These are 2 separate antennas systems and Will Not be connected to gather on to 1 coax.
The 2 Separate antenna systems / Separate coax systems will be separate all the way to the location of the Tv , and connected to remote control A/B antenna switch.
http://www.radioshack.com , #15-1968 .
http://www.mcmelectronics.com , #32-4425 .
http://www.saveandreplay.com , #32-4425 .
The hand held remote control of the A/B antenna switch is , Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep right on channel surfing.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
