Might as well install a large all-channel antenna with a pre-amp and rotor if you want to get all the local analogs that are still on the air for a while. Most of the local analog broadcasts are duplicates of the programs available out of Ottawa, so it's up to you if you want to chase them. However, if you are only interested in digital reception, you are likely able to get Ottawa and Watertown with a large 7-51 antenna, also with a rotor and pre-amp.
