Old 9-Aug-2012, 2:09 AM   #7
linux203
Antenna is up, need signal help.
So the RCA ANT751 arrived today and it's mounted near the roof peak pointed at 160 deg. Total cable length is about 110' with no splits and all external wire is new. (including grounding block)
I can pick up 18 and 9, but not 47. If I read my tvfool report correctly, 18 and 9 are 2edge and 1edge, respectively. 47 is Line of Sight and closer than 9.
Here's an updated TVFool Report to reflect an actual antenna height of 28 feet, not 34.
Do I need to repoint my antenna, get a preamp, or just accept that I won't get the channel?
Thanks,
Daniel
linux203 is offline   Reply With Quote
