Tv Reception.
As Always , antenna mileage numbers are a ->general <- target number for the general public.
A antenna has no way to stop receiving at 50 miles.
Strong Tv transmissions will be received past 50 miles.
Weak Tv transmissions might not be received to 50 miles.
The information you read about attics is , attics can reduce signal strength by 50% or more. There again , the number is a target number.
If the attic of your building is wood with wood or vinyl siding and the roof is the composition type singles and there is - No Metal Backed Insulation - in the attic and the roof is not metal and there are no solar panels then reception of the antenna in the attic will most likely be very good with a HD7696P antenna.
The Tv transmissions are Strong at your location , ->Many , many , many , many , many <- Tv stations are in the Green and Yellow colored reception zones of the tvfool radar plot report and Tv station channel list.
