Old 8-Aug-2012, 3:16 AM   #8
Tv Reception.
Here are the current Tv channels that are transmitted here in USA.
UHF band channels 14 thru 51.
There are No receivable VHF low band channels 2 thru 6 at your location.
The receivable channels at your location are 7 thru 51.
The HD7698P antenna receives channels 7 thru 51.
The HD7698P is the same as the HD8200U without the low band capability because you have no receivable low band channlels at your location.
There are No antennas that can see through trees like x-ray vision.
The HD7698P antenna is right at the top of the most powerful antennas.
Trees and tree leaves do a real fine job of reducing or blocking reception.
It is best to locate the antenna where there is the least amount or no trees in the direction of reception , north west.
The antenna can be moved to the side of trees and shoot around trees.
The antenna can be mounted up high to receive over the tops of trees.
The antenna can be mounted down low to shoot under trees.
And in some situations a antenna can be mounted Up High in a tall straight pine tree.
http://www.ronard.com/tree_adjust.html.
Also trees can be cut down.
It is now time to think creative about dealing with the trees.
