Old 8-Aug-2012, 2:25 AM   #3
Tv Reception.
I recommend a Winegard HD7696P antenna , no amplifier , aimed at about 340 degree magnetic compass direction.
The group of Tv stations/channels north and north west will be received.
That is All of the network channels , NBC , CBS , ABC , FOX , The CW , MyNetwork , PBS , and Many more digital main channels and digital sub channels.
I know it looks like many Tv channels to receive in the other directions but it really is not.
Most are Very Weak signal strength and will require Extreme measures to receive like a Winegard HD8200U antenna on a antenna rotator.
Of the the few that are stronger in the other directions , they more of the same that will be received buy aiming the HD7696P antenna at 340 degree.
More , NBC , ABC , CBS , PBS , etc.
WACS-DT Real channel 8 , virtual number (25.1) PBS is a Very Strong transmission and will be received through the back side of the HD7696P antenna that is aimed at about 340 degree magnetic compass.
If you choose to take a look at some of the other Tv stations around the compass install a Channel Master CM9521A rotor with the HD7696P antenna.
________________
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
______________________
As Always , trees and tree leaves do a great job of reducing or blocking reception.
Locate the antenna where there is the Least amount of obstructions in the the direction of about 340 degree magnetic compass direction , north / north west.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
