Old 8-Aug-2012, 1:31 AM   #2
signals unlimited
Pointing and aiming will not change much. Omni-directional has no real aim. The antenna pattern is duplicated with each 1/8 turn.
With most of your stations to your East to South, a better setup would be an RCA ANT 751 aimed to 129 degrees magnetic. This would deliver all of the channels to your East to South and some from the rear of the antenna to the NW.
If you have an attic with standard shingles and no foil backed insulation you could mount the antenna there. Better yet if you can, mount the antenna outdoors with a view from East to South.
