Old 7-Aug-2012, 8:49 PM   #13
In your first post your said you don't want to put the antenna on the roof. That is a significant handicap that may make successful reception much more difficult. You'll find less signal relative to interference down low.
Can you consider using a push-up telescoping mast to get above the peak of the nearby roof lines?
http://www.3starinc.com/telescoping_masts.html
