Old 7-Aug-2012, 6:48 PM   #3
Tv Reception.
Your location only has the UHF channels , channels 14 thru 51.
That is good , only one type and kind of antenna.
Install a Antennas Direct DB4e antenna (no preamp required) aimed at about 280 degree magnetic compass direction to receive the main groups of Tv stations That are to the north west and west.
________________
There is also WSPX ION Television to the north.
To try and squeeze it in , try aiming the DB4e antenna at about 315 degree magnetic compass direction.
The reason I say squeeze it in is , angle of reception , of the TV stations from the north west to the north is a , very wide angle , and the antenna might not provide good reception of the Tv stations on the widest part of the angle of reception like , WYST , WNYS and WSPX. It is worth a try it is a simple matter of turning the antenna to give it a try.
If it does not work then aim the antenna at 280 degrees.
______________________
So then if you will like to receive ION.
Install a second antenna aimed at about 1 degrees , north.
Install a Winegard HD9095P. no preamplifier is required.
_______________________
The 2 antenna systems will not be connected on to 1 coax.
The 2 antenna systems will be separate all the way to the Tv location and the 2 separate coaxes will be connected to remote control A/B antenna switch , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
An A/B antenna switch is Channel Surfing Friendly , push the button on the hand held remote control , change antennas and keep on channel surfing.
