Boston is an all-UHF city (except for a two-bit shopping channel). The two VHF channels on the chart are from Providence.
Azpilot,
Two things: 1) Move the antenna from behind the trees. Gain additional height, if possible 2) Add a high-input capability pre-amp.
If you want the two VHF stations from Providence, you will need to add a high-VHF antenna aimed in that direction.
Best of luck!
