Old 7-Aug-2012, 11:51 AM   #7
signals unlimited
When you install the AP 2870 amplifier and Roto 100 you can use the same single coax to both run the rotor and carry the signal provided you have no splitters between the rotor and the control box. If you need to install a splitter, use one that has a DC pass on one port and use that one for the line to the control box, or install the splitter on the coax line that exits the control box.
