Old 6-Aug-2012, 7:16 PM   #7
signals unlimited
Correct...aim toward both groups of stations and scan. Here is why:
The stations in both oposing directions are strong and nearly equal in strength.
The ANT751 will receive strong signals off the front and the rear of the antenna better than a larger more directional antenna.
Take it to the roof or anywhere that you can clear trees. Put it as high as possible and run the scans. You don't need another antenna, you need a site.
A larger antenna could make up for the site problem somewhat, but try what you have first.
