Old 6-Aug-2012, 5:42 PM   #3
HEADSHOK2002
Originally Posted by signals unlimited View Post
If you only care about is the top 7 on the list. Use a Winegard 7015 all channel antenna on the roof at a location with a clear view to the stations at 250 degrees magnetic. If and when these channels go DTV you will still be good to go.
Thanks for your quick response, SU.
I'm not sure if I only care about the "top 7" on the list... My thinking is that I'd like as many channels as possible. Really, the cost of these antennas are not terribly prohibitive, so I am open to a roof-mounted and amplified antenna if it will actually gain me some channels.
I was under the impression that all channels must be digitial, as of 2011 or whenever it was that analog was dropped. I'm obviously just confused about something, though, as you've confirmed that these channels are not yet DTV.
So with an antenna (any antenna) I will not be able to receive HD quality at the moment, correct?
I'm just curious as to what channels I can expect to receive, and what quality they'd be received in... "future proof" is definitely something I'd want, too, so (like you said) if/when they go DTV I'll be able to enjoy that upgrade.
HEADSHOK2002 is offline   Reply With Quote
