Tv Reception.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Older Tv's will have a Analog tuner and a Digital cable Tv tuner , The Tv might look like it is scanning for Digital Broadcast Tv Channels , when in fact it is scanning for digital cable Tv channels.
___________________________________
Un plugging the antenna Does Not make the antenna a non amplified antenna.
Un plugging the antenna makes it No antenna.
The amplifier is off and no signal gets through.
If a microwave oven is un plugged , will the microwave oven still work??
Plugging the antenna in , turns on the amplifier , and the signal gets through.
_____________________________________________
The Tv transmissions are Over The Top Strong at your location.
Do Not use a amplified antenna.
Is the balcony on the outside of the west/south side of the building??
Or is the balcony on the inside of the court yard??
Is there a window that faces west or south , on the outside of the building , not toward the court yard??
Are there big buildings to the west and south that are close??
The Tv transmitters are to the south west at about 211 degree magnetic compass direction.
