Thread: Cancelled Dish!
Old 6-Aug-2012, 7:30 AM   #26
bluefull
teleview, it would be difficult to borrow a TV but I can get my hands on my old Samsung set top box next week. The one I use to be able to pull Channel 21 with albeit not too well.
The antenna is still aimed at WLIW 21, I've left it that way since the change of direction caused no problems with the very strong VHF signals.
However, in addition to the drop in Signal Strength noted by the SiliconDust Config for Channel 21 post-balun and splitter change, I also noticed that Channel 5 now has occasional hiccups. Channel 5 was previously fine even with the antenna aimed at WLIW 21.
I considering the long-boom yagi if it can get past those trees. I will take a picture and post it. GroundURMast is there one on the list you provided that can be aimed primarily at WLIW 21 (UHF) but will also be able to pull in PBS 13 (VHF) from the other direction since PBS is only 5 miles away and the signal seems strong enough? That way I can save the cost of the additional tuner.
Thank you both for your help in troubleshooting this.
bluefull is offline   Reply With Quote
