Old 6-Aug-2012, 5:52 AM   #14
thom
grounded
Soil is not nearly as good a conductor as copper or other metals. Dry sandy soil is a very poor conductor. FWIW, in new construction, it's becoming quite common to see the foundation re-bar used as the 'ground rod'.
Excellent advice, thank you.
Yeah, that's my soil, and to make things worse, we only get thunderstorms in the summer when the ground has had 4 months to dry out.
On closer inspection, my situation is worse than I thought. The electrical service actually comes in through the foundation in the garage. The feed in is thoroughly encased in PVC. I did notice that both the legacy and the cable phone service run a wire to a screw on the outside bottom of the service panel. I don't see a good way to tap in, unless I run a wire to another screw on the bottom of the panel (assumptive ground).
thom is offline   Reply With Quote
