Old 5-Aug-2012, 11:42 PM   #4
Tv Reception.
The strap is put on a flat side of the chimney and bent around the corner and bent around the next corner and bent around the next corner , adjusted in the mounting bracket and then tightend.
No requirement to crank it down extra tight , but then do not want it loose and floppy either.
