Tv Reception.
Every time a splitter split takes place the signal is reduced.
Chaining splitters like you are doing , a splitter connected to an other splitter , reduces the signal even more , so at the end of the line there is not much signal left.
For your reception situation some of the Tv signals are a little weak , so a , distribution amplifier amplifies the signal a little , and a coax goes out to Each Tv location from the distribution amplifier.
The antenna is connected directly to the distribution amplifier , no splitters.
___________________________________________
It is amazing how easy I forget that people just hook up splitters at will , like using a 4 way splitter and a 3 way splitter to connect 2 TV's ??
So all this is Assuming there are 6 tv's connected.
------> So how many Tv are actually connected ?? <------
