Old 5-Aug-2012, 11:21 AM   #15
signals unlimited
The turning radias is the dimension from the antenna mounting point to the longest end of the antenna. The rotor would only be needed if you want to receive channels more than 30 degrees from your point of aim. The all channel antenna should be used if you want to receive any of the receivable channels on report that fall below channel 7. Otherwise you could use the lower profile 7697 antenna.
