Old 5-Aug-2012, 12:56 AM   #2
thom
Are you getting random drops on all channels or just 8 and 10? Since you're using the DB8, which is UHF only, your VHF reception will be spotty and not nearly as reliable as the UHF stations. Also, you might not realize you've got some LA stations in the mix, and those may come and go, given the distance.
thom is offline   Reply With Quote
