The DB4 with the kit is a very good choice. You will have a great improvment UHF and the VHF bi-directional add on the High VHF to the South should also work.
With all of the splits you have I would use a Channel Master 7777 pre-amplifier. This has 30 db gain on U/V, which will make up for most of the loss in your 4 and 3 way split including the loss in the coax.
