Old 4-Aug-2012, 9:20 PM   #7
RickInNJ
Signals Unlimited, that's a very interesting thought, thanks! Two low-cost antennas, one in each direction, is intriguing. The risk is sure low.
Teleview, many thanks as well for your suggestions. If going with the HD7084P, will likely try the two different orientations manually to see what comes in, then see if opting for a 2nd antenna is worth it or install a rotor.
Do either of you see an issue with going with a good pre-amp like the Antennas Direct CPA-19 preamp as GroundURMast suggests?
If either of you also have thoughts about the 2nd VA location, I'd be curious to hear them too if you have time.
Much obliged to all, thanks for your time and help!
RickInNJ is offline   Reply With Quote
