Old 4-Aug-2012, 8:45 PM   #5
RickInNJ
Very much obliged, Ground. Great thoughts and starting to look at the antennas and accessories you suggest for a good think through.
Sorry, 1 main TV in each location; don't really need more.
To get a rough idea of what's possible for VA reception (before installing an antenna in NJ), holding up the HD 7084P (or even HD 7080P) high in a piece of PVC pipe should work, yes? Just want to know the rough situation there before spending the $$.
The Antennas Direct CPA-19 preamp should also work in NJ if the HD 7084P was directed at NYC, and not risk flooding the signal for Philly, correct? [Could always turn it off for Philly stations, I guess.]
RickInNJ is offline   Reply With Quote
