Old 4-Aug-2012, 7:26 PM   #6
signals unlimited
Use the Winegard MS2000 omni-directional antenna provided that you have power available where you plan to use it, as it requires a power source to run the built in pre-amplifier.
If you need portability and are using a battery operated set where power may not be available, use the 'Sidewinder' un amplified omni-directional antenna from www.tripleplayantenna.com
