Old 4-Aug-2012, 6:29 PM   #1
RickInNJ
Would welcome your antenna recommendations for 2 locations
Hi,
This is a fantastic site compared to others (e.g. Antenna web). Thanks so much for all your tremendous work and help here!
Our location and specifics (in Central NJ):
  • Antenna likely to be mounted on chimney or roof, ~25-30 feet above ground.
  • Have tried an indoor amplified (Mohu), and gotten ~13-16 stations from Philadelphia if antenna is put on a glass door (inconvenient).
  • Surrounded by trees close to the house, esp. to the north, but would like to pull in NYC channels if that's possible.
  • Wondering if a good multi-directional would work for both NYC (NE from here) and Philadelphia (SW from here) channels, or whether a rotor would strictly be advisable.
  • Your recommendations on a pre-amplifier would also be most welcome.
  • Site Specifics: http://www.tvfool.com/?option=com_wr...9900a6c709b466
My parents (in central VA) are also considering pulling the plug on cable:
  • Attic install might be ideal (non-invasive).
  • Roof mount or possibly cheap tower may be possible. What would you recommend for each?
  • Some tall nearby trees to the South.
  • Would mostly like to pickup (North) DC channels, but possibly some to the South if that's possible/easy.
  • Would a good multi-directional work here, or would you suggest directional? (with rotor?)
  • Your pre-amplifier thoughts here? [Would guess the same as above, but don't know.]
  • Site Specifics: http://www.tvfool.com/?option=com_wr...9900a6f6785d5f
Last question: We expect good results in NJ given that the Mohu mostly worked and an external antenna should provide better. Would you think a trial of the antenna recommended for NJ (e.g. by holding it up manually in a PVC pipe or similar before doing any mounting) at the VA location would provide a good estimate of what reception would be possible??
Thank you yet again for all, and for this peerless service!
RickInNJ is offline   Reply With Quote
