Old 18-Jan-2010, 12:39 AM   #3
pcpro215
Thanks for the reply.
You are indeed, correct. I am between Green Bay and Milwaukee. However, I also live less than 1/2 mile from Lake Michigan. Should I be concerned about signal bounce? Is it possible to install/use an antenna rotor to capture more stations? Or, a multi-directional antenna to do the same?
Thanks again for your help!
pcpro215 is offline   Reply With Quote
