If your roof is standard shingles and there is no foil backed insulation, mount a Channel Master 4221 4 Bay UHF antenna in your attic. Aim the antenna to 136 degrees magnetic. If you can mount outside above the roof you can use a smaller Antennas Direct DB2 UHF antenna.
To connect four sets use a Channel Master 3214 distribution amplifier.
