Antenna and converter are received. I am seeing signals on the TV! I aimed the antenna at about 215 degrees magnetic and coverage is pretty good. The station I'm most concerned with is 10-1, NBC. Much of the time coverage is great but every minute or two there is lag in the audio and the video will get blocky. Sometimes this will continue for 30 seconds or so. It's pretty annoying when trying to watch a show. Does this sound like a reception issue or something with the converter? I currently have the antenna mounted on top of the TV with the antenna in the flat horizontal position. Vertical doesn't seem to help. Any other ideas? Thanks!
