Old 3-Aug-2012, 10:50 PM   #7
Tv Reception.
The second way uses No rotator.
The DB4e and YA1713 antennas are combined/connected as before on to one coax that goes out to the Tv location/s.
And can be at the 25 feet antenna height.
______________________________________________________
Also a Winegard HD9095P with a Winegard AP8275 preamp is mounted at the 60 feet antenna height for reception of the Tv stations/channels at about 108 degree magnetic compass direction.
This antenna system is not connected to the other antenna system.
This system also goes out to the Tv location/s.
The 2 Separate systems are separate all the way to the Tv location/s.
And are connected to the Tv/s with a Remote control A/B antenna switch at each Tv location/s.
Remote control A/B antenna switch is , channel surfing friendly , push the button on the hand held remote control . change antenna systems and keep on channel surfing.
http://www.radioshack.com , # 15-1968.
http://www.mcmelectronics.com , # 32-4425 .
Here are some ways to get the antenna 60 feet above ground.
Light weight , Aluminum , No guy wire , Lay over tower , Do all antenna installation and adjustments standing on the ground.
http://www.palcoelectronics.compe300.aspx
http://www.3starinc.com , has towers and push up poles.
Search on the internet for used towers and push up poles.
Yes I know what you will say , this all adds up to some , $ change.
Well Ok , how much does the pay cable or pay satellite cost each year , 5 years , 10 years , etc. ??
