Tv Reception.
Ok , at no less then 60 feet antenna height at about 108 degree magnetic compass.
WGLC-DT Real channel 19 , virtual number (46.1) CBS
WPCH-TV Real channel 20 , virtual number (17.1) IND.
WGTV-DT Real channel 8 , virtual number (8.1) PBS
WXIA-DT REAL channel 19 , virtual number (11.1) NBC and Local Weather
WAGA-DT Real channel 27 , virtual number (5.1) FOX
WUPA Real channel 43 , virtual number (69.1) The CW
WATL-DT Real channel 25 , virtual number (36.1) MyNetwork and Bounce Tv and Antenna Tv
WHSG-TV Real channel 44 , virtual number (63.1) Religion
WUVG-DT Real channel 48 , virtual number (34.1) Univision and Telefutura
WATC-DT Real channel 41 , virtual number (57.1) Religion
_________________________________________________________________
There are different ways to set up antennas for reception.
This First way the DB4e and YA1713 antennas will not be used.
Install a Winegard HD7698P antenna with Winegard AP8275 preamp mounted on a Channel Master CM9521A antenna rotator.
At no less then 60 feet antenna height.
The HD7698P will rotate to receive the Tv stations/channels in the directions of ,
50 degrees , north east.
108 degrees , south east.
220 degrees , south west.
A advantage of using a rotator is the antenna aim can be adjusted to get the best reception of tuff to receive Tv station.
A disadvantage of a rotator is not channel surfing friendly , must wait for antenna to rotate and not every one will agree on the direction the antenna is aimed.
