Outside on the roof would be better, but if the attic is the only option, install a Channel Master 4228HD 8 bay UHF antenna aimed to 153 degrees magnetic. That should do the job provided your home has a standard shingle roof with no foil backed insulation under it, or in the walls.
You don't need an amplifier unless you are connecting more than four sets and have long runs of coax.
