Old 3-Aug-2012, 8:18 AM   #2
Tv Reception.
A simple reception situation.
Above the roof install a Winegard HD7000R antenna aimed at about 330 degree magnetic compass.
Here are places to by antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
The Tv/s Must Channel Scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
