Old 3-Aug-2012, 6:42 AM   #1
farfigngn
Best HDTV antenna for my attic in Westchester NY
Hi. I was hoping someone could make a recommendation for an antenna I can mount in my attic. Here is my TVfool info: http://www.tvfool.com/?option=com_wr...99002230a52198. This would be a new install. There is no cables run yet and I would prefer not having to use an amp if possible. I was looking at the Winegard FV-HD30 and the HD1080. I also read about members using a mid-sized outdoor antenna in the attic with a little tweaking. The house is on a bit of a hill and the South / SE exposure is pretty clear and I am about 20 feet higher than my neighbors house in that same direction. I can see the tree tops from that side which points toward the city (NYC). This might be a separate topic, but that same neighbor has a ham radio station antenna cutting right through the middle of that view. Dont know if that might hinder my reception. Any info would be great. Thanks.
farfigngn is offline   Reply With Quote
