Old 21-Sep-2010, 2:03 AM   #1
helpmeplease
Got 27 Channels in Basement, 4 in Living Room with same antenna position and cable
We're stumped. We have a Clearstream 2 antenna and a Sony Bravia Digital LCD TV.
We started by trying the antenna with a short cable to the TV. On the ground, outside our sunroom (adjacent to the living room) we got 27 channels - all the local ones we'd expect.
We tried the short cable with the antenna in the living room. No channels at all.
So we mount the antenna about 16ft up on the side of the house pointing at 218 which is what we got the 27 channels with and what it would seem from our chart should work, then snake cable down to the cellar where all our coax is routed from for the house. Back up to the living room. Tune. One channel - PBS on 2. Not perfect either.
Next we try just connecting the TV to the cable direct from the antenna without connecting into the house coax set up (which we wanted for splitting and using another TV in the kitchen at some point). 27 channels crystal in the cellar. Yay, we thought.
So, same cable, same length, same connections just pushed up to the living room from the cellar. Tune. 4 channels (2.1, 2.2, 4.1 and 5.1).
Tried redoing the connections. No success.
What on earth could make it receive all the channels in the cellar but not in the living room with the same connections and cable length?
Your help is most appreciated.
Thanks!
Here's our chart: http://www.tvfool.com/?option=com_wr...a3622efea31c9f
helpmeplease is offline   Reply With Quote
