Tv Reception.
My recommendation is now set.
One antenna above the roof , HD7084P antenna connected to a CM distribution amplifier.
Mounting a antenna above the roof of a one story house is about 25 feet above ground.
The coax/s that go to the Tv/s will connect to the distribution amplifier , the coax from the the HD7084P antenna will connect to the distribution amplifier , the distribution amplifier can be located in the attic , most attics have a electric outlet in the attic or the distribution amplifier can be at a other location that has electric power outlet and is out of the weather.
