Tv Reception.
As has come up -> repeatedly <- in other question askers posts.
KCWX is not transmitting on channel 8 so that leaves the reception of KCWX channel 5 to receive.
Install a All channel antenna.
All channels are , VHF low band 2 thru 6 , VHF high band 7 thru 13 , UHF band 14 thru 51.
Install a Winegard HD7084P antenna above the roof so the antenna is not blocked by the house or by the roof.
Aim the HD7084P antenna at about 240 degree magnetic compass.
For 1 Tv connected install a Channel Master CM3410 distribution amplifier.
For 2 Tv's connected install a CM3412 distribution amplifier.
For 3 or 4 Tv's connected install a CM3414 distribution amplifier.
The CM distribution amplifiers are not , direct weather proof , so run a coax from the antenna to a location that has electric power for the CM distribution amplifier.
And connect the antenna coax to the CM distribution amplifier there.
Most attics have electric power outlet.
Or can put the CM distribution amplifier at a other location that is out of the weather and has electric power.
Of course the coaxes that go to the tv's will also connect to the CM distribution amplifier.
