Old 3-Aug-2012, 12:21 AM   #4
Tv Reception.
Based on the provided tvfool radar plot report and channel list.
The receivable Tv stations/channels to the north east are UHF Tv channels.
Install a UHF Tv antenna.
Aim a Winegard HD9095P UHF antenna with a antennas direct CPA-19 preamp at about 57 degree magnetic compass.
Thats the weakest signal strength Tv station WFUP channel 45 FOX , that is in between the stronger Tv stations on either side.
For 2 Tv's connected use a ,
HFS-2D , 2 way splitter.
For 3 Tv's connected use a ,
HFS-3D , 3 way splitter.
The HFS splitter pass power from the power supply/power injector from inside the house to the actual preamplifier mounted close to the antenna.
http://www.hollandelectronics.com , and also at , http://www.solidsignal.com
Most likely adjustments will be made. , the Final antenna height and Final aim direction.
For best reception.
I do not think a antenna rotator will be required.
IF a antenna rotator is required , CM9521A.
As always , trees and tree leaves do a great job of reducing or blocking Tv reception.
Mount the antenna where there is the least amount objects in the way of reception of a span from 10 degree magnetic compass to 90 degree magnetic compass.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
The Tv/s Must Channel Scan for Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
