Old 2-Aug-2012, 10:45 PM   #1
Cabal
Impossible Astronaut
Cabal's Avatar
Antenna suggestion mounted on lower roof
TV Fool report here: http://www.tvfool.com/?option=com_wr...9900db0209c300
I'm looking at working with a 5-foot mast and wiring left behind by the previous homeowner (or replacing the latter). It's on a lower roof set back about 15 feet from the house, and will be 15-20 feet in the air when all is said and done. I would prefer to reuse this location rather than setting up something new on top of the house. The direction of the local tower farm (230 magnetic) would put the antenna pointing to the right of the chimney from the second picture.
Given the need for *some* VHF to pick up Fox locally, and hoping for a smaller setup. I was considering the DB4e + CS2-V VHF reflector attachment (see http://www.digitalhome.ca/forum/show...&postcount=371) + pre-amp. Given the disadvantage of being on the back side of the roof and the location outlined above, would I need a full Yagi instead? Also, any considerations for vertical tilt? Thanks.
Cabal is offline   Reply With Quote
